Oil extractor question
I believe some of you have used a vacuum pump of some kind to drain the engine oil without using the drain plug with the added 'fun' of fighting with under-trays etc. I'm keen to give this a go as the Cistern has started whingeing about a service...
Any recommendations on a suitable gadget?
TIA
TIA
Re: Oil extractor question
I see 'Pela' oil pumps talked about with enthusiasm on the Volvo Forum.
TBH I want one because it's a proper PITA wrestling with the undertray and last time I did it on my cold concrete floor it made me feel quite ill with the near constant little knocks to the noggin
2005 Volvo S40 T5 German Diesel botherer with new tyre grippage
Mityvac 7201,
Not cheep but a brilliant bit of kit.
There are cheeper but you get what you pay for
JB Tools seem the cheepest, the MV7400 should be enough for your needs
The Sealey S01169 might be enough @ 6.5 litres & a bit cheeper still at Toolbay.
) for sale
2006 BMW e61 535d m-sport
run's for cover
& This is why I'm less enthusiastic than Bailes with regards to my gearbox oil flush, I'd be doing itWelly wrote: ↑Tue Oct 20, 2020 10:23 am I see 'Pela' oil pumps talked about with enthusiasm on the Volvo Forum.
TBH I want one because it's a proper PITA wrestling with the undertray and last time I did it on my cold concrete floor it made me feel quite ill with the near constant little knocks to the noggin![]()
outside on my driveway (which is a 20% slope) just jacking a car up at home presents it's own challenges
) for sale
run's for cover
Pela 600, Mitivac, I'm seeing all sorts tested and approved but it's mostly Yank stuff unfortunately. I've also seeing those little fluid transfer pumps being used for it, the sort of thing that was in Lidl a couple of weeks back...
1991 Yamaha TDM850 - maybe fixed but in the dog house
2008 Toyota Recall4 2.0 VVTI ATM (Anti-Theft Mechanism) LHD JTMBH31V90D007261 - flimsy piece of crap.
1953 Matchless G3LS - it weighs a ton!
Thank you all for the quick replies.
Pela looks like £48/£49 delivered.
Sealey £42.25 from Tools4Trade with free delivery for orders over £50, (must be summat else I needs)'
(Toolbay is £49.95 + delivery £?)
Mityvac 7400 £49ish + delivery
Mityvac 7201 £67ish,
interesting comparison here https://www.youtube.com/watch?v=lp1Rwi8QnEs
After watching that video I'm thinking external vac pump like the Mityvac 7201 is the way to go, not yet sure if the Pela and/or Sealey have that feature. Thinking to go look see at local suppliers.......
Some brief 'youtubing' seems to say that you'll be cranking that Pela pump almost every minute to maintain a vacuum, don't think I'd like that.
I saw Lidl's oil pumps recently but the fluid-transfer rate seemed very slow....so much so I read the specs on the packaging and put it back.
Ah well, I didn't even look at them 'cos the only liquid I need to pump around these days is rainwater, and I already have some pretty good pumps for that.
- Bailes1992
You're all a bunch of pansies. If your armpit isn't full of oil at the end of an oil change, did you even change the oil?
I think to me it's more about the time; jacking the car, axle stands, wrestle the undertray (then later fabricate some elaborate tie-wraps and washer fixings*) transferring oil between containers.....
I do 4 oil changes per year and if there was an economical way of quickly whipping out old oil then I'd go for it. To be honest though I don't think I want to spend £50 to £70 on this right now. I've actually got the oil service kit for the Shitroen right now - awaiting me clearing some garage space to do it
I guess you're right - I've even taking to wearing glovesBailes1992 wrote: ↑Tue Oct 20, 2020 3:52 pm You're all a bunch of pansies. If your armpit isn't full of oil at the end of an oil change, did you even change the oil?![]()
True.Welly wrote: ↑Wed Oct 21, 2020 8:29 am![]()
I do 4 oil changes per year and if there was an economical way of quickly whipping out old oil then I'd go for it. To be honest though I don't think I want to spend £50 to £70 on this right now. I've actually got the oil service kit for the Shitroen right now - awaiting me clearing some garage space to do it![]()
I have an unsightly corner under the hedge with a minging basin + funnel, couple of mats to lie on and a souvenir 406 undertray.
Spending more than I want to on said pump would probably motivate me to clean it / stash in the shed.
I get through loads of Nitrile Gloves
That's if you can afford them - seems only now the OMGCOVID fair* pricing scheme is only just settling down - think I paid £10 for 100 gloves 2 weeks ago - they have been more than double that recently
- Bailes1992
I tend to have an oil change day twice a year. I let everyone know that I'm changing oil and if they want theirs done to bring a car and a filter. I usually have 30-40 litres of oil in the garage at any one time. Usually I bulk buy something with Porsche A40 approval as it's a very stout and tough specification coupled with ACEA C3 so it's Mid-Saps, a good 'universal' oil so to speak. Alternatively I look for VAG 504/507, again it's a very stringent specification, will do 20k intervals if needed in most engines and is emissions equipment safe being Mid-SAPS. Buying in bulk I can usually get the cost down to £2-£3 a litre.
I'm not a huge fan on crawling around under cars and getting covered in oil, BUT I do find oil changed therapeutic.
The used oil in the Citroen comes out extremely thin/runny I think Diesel fuel gets into the sump on regens so it's nice to know you've added fresh oil just to save the poor thing from more hardship.
John Cleese wrote: "Oh, I like it runny"
