Supply sensors, EGR
NinoB
2.2 16v
Supply sensors, EGR
Post by NinoB »
Hello
This same car with another issue
1. Position EGR solenoid valve : permanent fault, short circuit to earth
2. Supply to sensors short circuit to earth
I replaced the EGR with new EGR, and i actuated it, but still is showing EGR fault, and the rpm keeps fluctuating above 1000(despite i change the injector mouth i.e motorizee) ,
Meanwhile i don't what supply sensors means?
Any suggestions?
I attached the faults below
Re: Supply sensors, EGR
As per your other post, it is possible the power supply for the solenoid valves on the bulkhead is missing or has a poor connection. Without access to the diagrams its not easy to trace these faults but I would suggest taking precautions for disconnecting the battery then testing all the fuses in the engine fusebox.
I seem to recall an old post about an improvement made to the earthing for some of the engine sensors to eliminate something of this sort, anyone remember or have a clue how to find it?
NinoB
2.2 16v
Post by NinoB »
Ok.. Lemme check the fuses.. But today I tested the Continuity of each and every wire of cylinder reference sensor, EGR, TPS, inlet manifold sensor, throttle potentiometer all down to ECU.. All the wires are continuous..
Phew.. The car is full mux.. Let check the fuses
NinoB
2.2 16v
Post by NinoB »
I tested a different ecu and bsi and everything worked fine.. It means my ecu is bad, i need to replace it
Have you checked the actual obd2 port on your car?
Is one of the holes slightly damaged or corroded?
NinoB
2.2 16v
Post by NinoB »
The port is ok.. Like I said i tried another bsi and ecu on the car.. Then scanned.. All fault gone.. So i concluded that the ecu is bad.. Now i have to buy used bsi ecu and key..
Anu suggestions where i can get cheap working types?
Oh I see - I thought you tested your PP2000 on a different car - my apologies
NinoB
2.2 16v
Post by NinoB »
Thanks sir
frog
Post by frog »
After swapping both the BSI and the engine ECU, did you actually start the engine?
Many faults will only appear while the engine is running.
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
NinoB
2.2 16v
Post by NinoB »
Yes i did.. Car started
No fault..
I wish I could buy complete system like that..
