All 406s have a 4 digit ( stamped on the NSF strut top under the bonnet early models ) or a 5 digit number ( on later cars it's on a sticker on the drivers door pillar ). Sometimes the OPR is referred to as the DAM number.
Basically, as the car evolved over the years changes were made to the wiring, or the engine, emission systems etc - this number will determine if the part will fit your generation of 406.
Have a look on your car, if it's a late one then it'll be a number like 09123 ( ignore the first digit when using diagnostics )
2003 2.2hdi estate - mine 1998 Volvo 940 auto estate - also mine 2019 Citroen C3 something - the wife's PP2000 user, can help with faults / diagnostics in the Bournemouth area.
I've checked both of my strut tops and there is nothing and on the sticker there are 2 numbers 0943789 and 20203 but none of them looks like is the correct length. Do I just read them wrong or am I looking in wrong places?
Your number is 9437 - the 89 on the end refers to the factory where the car was produced ( I had forgotten that bit, sorry.. )
Popular colour too
Nice, and when it finally starting make sence I get something like this:
Both parts are Sing OPR 09338 which is lower than my OPR number... but there is that 'and age >= 2' what does that mean?
Can both parts be used? Actually there are 3 part numbers are marked in red... so confusing sometimes
Unfortunately the parts list is not infallible.
Example I've used it for air conditioning seals only to find they had actually built the car with the supposedly superceded parts.
Can be helpful if there is a physical difference between the alternatives and you can see which one you've got.
Many parts, like alternators a/c compressors etc. will probably be interchangeable as they would have swapped between alternative suppliers for cost and/or availability reasons
GingerMagic wrote: ↑Sun May 15, 2022 2:50 pm
89 is Sochaux, most saloons & estates seem to have been born there.
The age thing used to mean second-line spares (i.e. cheap crap) but this seems to be a recon part - if the car's less than 2 years old give them a new unit but if it's more than that fob them off with a recon. As far as I know they only fitted 2 (so I've no idea what the PSA one is, probably junk) https://www.406oc.co.uk/viewtopic.php?p=151849#p151849
I got another one.. this time the part that is needed is missing.
Any idea how to get the part number if it is not there?
On ebay/eurocarparts/autodoc etc. I was able to find the condenser that I need and the listed OEM parts numbers are: 6453.EC, 6455.AS, 6455.CQ, 9636722480, 6453EC, 6455AS, 6455CQ
Killerko wrote: ↑Tue Jun 28, 2022 12:58 pm
Are you using an offline backup of servicebox?
Where did you get yours from?
Yes, I managed to download a set of .ISO files containing the "SEDRE" and "DocBackup" (ServiceBox) DVDs. Although not the latest versions, they perfectly cover our types of vehicle.
I mounted the DVDs onto a "VirtualBox" image of Windows XP. It was quite a learning curve to get it all installed but it works reasonably well now.
Current "fleet": 2003 406 Estate 2.0HDi 110 - 7 seater - just hit 710.000 kms 2001 Citroen Saxo 1.6i 8v 100
Previously owned: 2000 406 Sedan 2.0 HDi 90 2000 406 Coupé 2.0i 16v 138 - Riviera Blue
Killerko wrote: ↑Tue Jun 28, 2022 4:08 pm
Was that from official servicebox website you downloaded them?
Or some 'other' source?
Would love to get a copy if they are still available somewhere.
No, not official. I think you can buy (read: "get a download link") via various sellers on Ebay. IIRC I found my set via a well-known peer to peer file sharing system. Or just google around a bit, you'll find your way.
