Thinking about it now due to the water pump bearing now squealing I'm thinking the belt was probably over tensioned, is this a possibility?
Replacing the belt and pump is not beyond my capabilities but my old 18 volt torque gun decided to have a smoke up when trying to undo the crank pulley bolt so I have stalled for now. Thinking I could lock the flywheel with an 8mm bolt to try and have a go at the pulley bolt with a bar and socket I was miffed to find no hole in the engine block to pass the bolt through into the flywheel! There are two m6 threaded holes facing forward on the casing near the starter motor aperture though which I'm guessing is for a toothed locking tool to fix to. Is this the norm on the auto and would anybody know what the locking tool part number is please?
I was hoping to get the job done over the weekend but should have known the crazy Frenchmen would have put something in to trip me up
Cheers,
Paul
