Spark Plugs
- 1.6 8v
hi
under the cover lies the coils, there are three 8 mm bolts holding them, under them lives the spark plugs
there are only 2 types recommended by peugeot
EYQUEM: RFN52 HZ
Bocsh: FR 8 ME
other manufacturers like Beru, Denso have equivellant numbers.
But I believe you should stick to bosch
EYQUEM: RFN52 HZ
Bocsh: FR 8 ME
Changed the filter to K&N, put Bosch plugs and switched to LIQUI MOLI 0W40 oil.
It drives like a charm now
I have had problems with Bosch's in the past so have been put off to be honest. I have always liked Denso's.wafeeq wrote:hi
EYQUEM: RFN52 HZ
Bocsh: FR 8 ME
- jameslxdt
denso are too expensive and are best left on jap crap
ngk's are the best for pugs, if you went to pug for plugs you would either get eyquem if your really unlucky, bosch if your lucky, or proper ngk's if the parts man likes you
- DaiRees
- jameslxdt
i know, but we aint talking about the [s]crappy[/s] HPi now are we?
- DaiRees
- jameslxdt
sticky cam follower or duff injector
when was the last time it had an oil change?
- jameslxdt
are you one or two year servicing intervals?
- DaiRees
- DaiRees
- jameslxdt
yeah, i think an oil change is called for, take it for a 30 min motorway blast to get the old oil red hot then drain it, and use castrol edge 0w40
or mobil one 5w40
or mobil one 5w40
- jameslxdt
no problem
is the problem anything like what happend before with the egr?
