406 d8 release bearing
hi i am in the middle of doing a clutch on my 406 2ltr 16v r reg. i have got down to dropping the dam thing out but i seem too be stuck on the thrust bearing:frown: how do i get it off? , its a backward clutch with a dmf. thanks
bla bla bla
- jameslxdt
yes its a backwards clutch, but you dont have a DMF, the reason your having trouble with the release bearing is because its part of the pressure plate, the gearbox should just come out and the fork will slide off the release bearing but reffiting is a right arse, it took me nearly three hours when i did mine, you have to align the release bearing and have the fork at the right angle so they lock into each other when you fit the gearbox back, otherwise the gearbox wont go back on
thanks which position is the clutch leaver in the box when you take the box out (fwd back) or does it not matter? i have got both shafts out bellhousing has come out about 2-3 inches but i cannot get the bearing of the clutch leaver, the box itself is loose i can giggle the thing around no probs just wont release off the bearing. any little tricks to persuade the thing out ? ive been trying for hours
bla bla bla
