Towbar Wiring.....HELP PLEASE!!
Mike84
Post by Mike84 »
Hi,
I have fitted a towbar to my car over the weekend and have come to do the wiring and got stuck! I thought that the trusty Haynes manual would help but no, just confused me even more.
Can anyone tell me which wires in the car I need to connect the seven core upto.
Also another thing, Now I have fitted the towbar the heat shield for the back box wont go back on! Its even more difficult as 2 of the 4 bolts sheared off when trying to remove it!
Mike
Mike84
Post by Mike84 »
can anyone who has a towbar fitted to there 406 please have a look and see which wires from the car connect to the 7core cable from the 7 pin socket
mike
what car have you fitted it to ???
Mike84
Post by Mike84 »
Hi,
Its a W reg Saloon,
Mike
sorry mine's an etate and wouldn't even know where to start looking
should be someone on here that can help though
Hiya mate, my pug doesn't have a towbar, but I recently fitted one to my jeep and simple used a tester to find the appropriate wires.
Plenty of how-to guides and diagrams on 'tinternet. I assume since you're only asking for one socket you're after the lights for any trailer board, caravan etc, which is a 12N. (If you need the auxiliary power for a caravan, that's a 12S. )
Any of these any use to you?
http://reviews.ebay.co.uk/Trailer-plug- ... 0002022212
http://www.rydertowing.co.uk/trailer_to ... wiring.htm
http://caravanning4u.co.uk/towbar.html
Did the kit not come with wiring instructions???
:D
Mike84
Post by Mike84 »
yes it came with instruction mate, it tells you exactly what each wire from the 7 core cable does but not what wire to connect it too!! :?
Mike84 wrote:yes it came with instruction mate, it tells you exactly what each wire from the 7 core cable does but not what wire to connect it too!! :?
So take the cover off the back of the rear light clusters and have a look which coloured wires go to which bulbs....
jameslxdt
Post by jameslxdt »
as you have a BSi, there is know flasher unit for the indicators as the BSi triggers them, you need to get a flasher unit and a lot of rewiring
Mike84
Post by Mike84 »
Thanks,
I have sorted them out now, after a bit of trial and error.
The indicators work fine as well and I have just wired straight into the existing circuit. All I need is a buzzer relay as the one that came with my wiring kit didnt work! Need to take it back.
At the moment it looks a mess on the back with the standard towbar on, but I am waiting for the detachable kit to come in stock at the shop.
