Running Temp - D8 2.1TD
Tiny Tim
Post by Tiny Tim »
Can any owners give me a rough idea of the running temp on the above? Mine sits at about 80degrees on normal driving in the current weather but hits just over 90degrees when at a standstill. Is this acceptable? Also, can anyone tellme when the fan SHOULD cut in?
Many ta's! :cheesy:
That sounds about right to me, also Heinz says 83° C. I'm not sure about the fan, mine has 2 and hot climate air con so it's probably different. I'd think when it gets to 90 the fan should think about comming on. Heinz says "before it gets in the red", which is very useful.
Tiny Tim
Post by Tiny Tim »
Cheers Steve.
Not sure I fancy sitting there waiting for it to kick in though :shock:
jameslxdt
Post by jameslxdt »
sounds spot on to me, 2,1 fans should kick in at 92 i think, you wont hear them though
Tiny Tim
Post by Tiny Tim »
nice. thanks again guys.
