hybris turbo
Malachy
2.2 16v
Post by Malachy »
niz406 wrote: it will only have an oil feed/return and no coolant connections, this is no good for the petrol turbo as it runs much hotter behind the engine and requires the coolant to stop the oil from coking.
o i guess my oil only t3/t4 roller bearing turbonetics turbo is no good then, or all the t3's that come on rs fords.
rubbish most big power cars dont use water cooling on the turbo as it over works the cooling system, just run an oil cooler and decent synthetic oil (good quality synth such as mobil 1 will not coke anyway).
the only benefit you get from running a water cooled turbo really is the fact you dont need a turbo timer since the water cooling prevents the need for one. and er thats about it.
Regards
Andy
1996 306cab with a few mods
Rather than cooling the Turbo to any degree the water connections also work as a nice winter coolant pre-heater.
My collegue removed the water conns on his twin TD04's and put them through their own water coller/fan and electric pump. The very most he's had on that system is 60 deg C. On the motorway at cruising speeds the water normally runs at 35 deg C. So the turbo water conns don't really do much - which had us surprised a bit.
niz406
Admin <BR>Turbo God
Post by niz406 »
In that case, you do not want to do the whole bigger compressor wheel etc... just a dynamic oil seal kit or carbon seal kit with a 360 degree thrust bearing set up... this will allow you to run the extra psi and keep it alive!
Niz406
niz406
Admin <BR>Turbo God
Post by niz406 »
Malachy wrote:o i guess my oil only t3/t4 roller bearing turbonetics turbo is no good then, or all the t3's that come on rs fords.
Regards
Andy
Due to the size of yours dude, heat isn't really that much of a problem and you have to take into account where yours is mounted.... as for escorts and sierra's its the same story there..... they are typically mounted at the front.... or the side of the engine.... not behind the block with no real cooling effect from the outside world.
So yes, the coolant feed is needed on the pug's..... a turbo timer, allows cool oil to circulate the blower at idle before switching off..... watercooling of the turbo.... which is a function to keep the oil cooler at the optimal viscosity.... does it work..... not when the turbo is used beyond it's specification.
Niz406
pug306tdi
1.6 8v
Post by pug306tdi »
i just bought 2 charge coolers for the 306 and the 406 1 each. i am looking into fitting them will thay make much of a diffrence compared to a FMIC?
pug 306 tdi 150bhp blaze yellow
niz406
Admin <BR>Turbo God
Post by niz406 »
pug306tdi wrote:i just bought 2 charge coolers for the 306 and the 406 1 each. i am looking into fitting them will thay make much of a diffrence compared to a FMIC?
Who's did you buy?
Niz406
jameslxdt
Post by jameslxdt »
there will be so much lag on the 306 you wont feel any torque, no point in a hybrid, just do as i said and go for a gt15 or kkk ko3, as lag is the killer on the 306, as you know after 3k revs the torque drops off like hitting a brick wall :lol:
pug306tdi
1.6 8v
Post by pug306tdi »
on my 306 the turbo is still boosting hard at 4800 rpm it revs to 5200 rpm freele then it drops off i done a stage 1 tune on it plus the cam wen im crusing i change at 3000 rpm wen im racing i change at 4800 rpm still boosting hard
as for the charge cooler i dont kno who makes them all it got writen on the front it "charge" thats it
Tiny Tim
Post by Tiny Tim »
Urrghh charge coolers :? heat soak urrghhh :lol:
Gimme a FMIC anyday 8)
niz406
Admin <BR>Turbo God
Post by niz406 »
Courtney sport do a quality set up for vaux turbo's lol
Niz406
pug306tdi
1.6 8v
Re: hybris turbo
Post by pug306tdi »
thay phoned me and said thay cant get the cooler to me a distribucion plroblem so im keeping the FMIC or i might buy a charge cooler not sure yet
i have a air to air IC at the mo but what is a water to air cooler?
Tiny Tim
Re: hybris turbo
Post by Tiny Tim »
Water to air is a charge cooler... charge coolers have a motor which pumps the water/antifreeze mix around a circuit and through a pre-rad. Its gos through a charge pot which is where the charge air goes through.
pug306tdi
1.6 8v
Re: hybris turbo
Post by pug306tdi »
aaaa right i get u thanks for clearing that up 4 me.
i have decided to go for a greedy intercooler in the front bumper made to fit adn i am ordering a hybrid rebuld kit of the bay wen i get paid next week
cheers guys for your help youve been a big help
thanks again
jameslxdt
Re: hybris turbo
Post by jameslxdt »
pug306tdi wrote:on my 306 the turbo is still boosting hard at 4800 rpm it revs to 5200 rpm freele then it drops off i done a stage 1 tune on it plus the cam wen im crusing i change at 3000 rpm wen im racing i change at 4800 rpm still boosting hard
what?????
i used to have a 306 tdi and there is no way it would rev anywhere near 5k rpm, after 3k rpm the torque stopped and then after 4k rpm there is absolutley no power at all
your pump must be proper fooked
niz406
Admin <BR>Turbo God
Re: hybris turbo
Post by niz406 »
what?????
But he has stage 1 ????
Niz406
