Climate control relay?????
powerslider
Post by powerslider »
Hi guys, is there a seperate relay for the climate control. Is so where can i find it. The climate control panel is not working at all, tried the fuses and checked all wiring to the ignition to no avail.
There seems to be a lack of relays in the car, where do i find them.
Any other ideas to the problem.
The car is a 's' reg 2.1 td glx.
At the mo have no heating and no fan.not good in winter :
Re: Climate control relay?????
try the wires at the rear of the ignition switch 8)
powerslider
tried them my friend but no joy.
any other ideas
There should be a fair collection behind the fuse panel.
Haynes doesn't have a wiring diagram for the air con either :(
In my D8, the air con is controlled by the relay at the back of the dashboard, behind the pedals. You'll need to take off the cover (3 plastic lugs to remove) to get access to them. There will be 2 black relays next to each other. One controls the front fog lights, the other does the air con and rear heated windscreen. Well, on mine anyway.... But then, I don't have climate control, just plain old air con (less things to go wrong, you see... :P)
jameslxdt
Post by jameslxdt »
my first 406 did this once i gave the side of it fair whack and it seemed to fix it :lol:
What's known in the trade as "percussive maintainance"... :)
Ah, the old persuader! Every toolbox should have one! :lol: :lol:
Sorry for the double post, I only clicked submit once, honest! :oops:
powerslider wrote:Hi guys, is there a seperate relay for the climate control. Is so where can i find it. The climate control panel is not working at all,
If the panel's completely dead, it's more likely than not going to be the connector at the back of it having fallen out, failing that you'll want to get another from a scrappy
powerslider
The connector block is fine, no loose wires etc, have exchanged the unit for a tested one at my local pug specialist and still no joy.
Looking like its a job for a auto electrician or the main dealer.
Bummer. I'd suggest chasing it with a meter but I know once those wires dissapear inside the loom it's anybody's guess. Auto electrician will probably be the safer bet, probably cheaper and actually knows what he's doing...
