Fuel filler cap light
Recently left filler cap at garage after fill up. Only noticed the next day that dashboard warning light on (top left end of dash and hidden by steering wheel).
Found a replacement cap on ebay. It fits perfectly but dash light remains on. Any ideas why light still on, or how i can turn it off??
jim
jim
Re: Fuel filler cap light
You do realise there's a hook on the bottom of the flap for holding the cap don't you? (only noticed it when I got the D9
There's a light? That's a new one on me! And I've had that all to pieces on my D9 too!! Maybe it's a UK thing... Obviously there was something on your cap that the new one lacks, have a squint in the filler neck to see if you spot any switches or anything (right there? Are Pug mad??). Maybe you can knobble it, disconnect it or modify yur cap. Failing that, it's off to Pug you go
>wanders off to look on Sevice box<
I have a 2000 HDi 90 Rapier. Found out about the hook on the flap when reading manual afterwards trying to suss out the dash light! I'd never noticed it before.
Can't see nothing electrical around the cap. Think i'll just live with the light on.
jim
jim
You could always take the clocks out and remove the bulb...
- DaiRees
Some of us get the really posh multifunction display warning message
I only found out when this subject came up on the forum previously and I went outside to experiment. Can't say I noticed a dash light for it though, guess that needs further experimentation
Now *that's* not something you can ignore!
Ah, those lovely messages, my favourite is "automatic wiping active", not something you'd want to see if you were using one of them high-tech bogs down in London...
- Site Admin & Mad Biker!
And it costs you 20p or whatever!
There was an old thread on this.
If I recall correctly there was an intrinsically safe reed switch in the filler neck that detects the cap by a magnet.
406 Coupe S HDi
PP2000 clone interface
406 Coupe S HDi
- jameslxdt
you've fitted the wrong type of capJimH240 wrote:Found a replacement cap on ebay. It fits perfectly but dash light remains on. Any ideas why light still on, or how i can turn it off??
jim
Cap works so just going to leave it with the light on. Thanks for replies.
Love that posh multifunction display warning message though. Should be standard.
jim
jim
hi jim just had same problem if you go under car behind drivers side rear wheel you'll see wiring running down from the reed switch,it follows the filler neck to the tank,follow it and theres a multiplug before it disappears under car disconnect it cover both ends with insulation tape and tuck in somewhere so it's not hanging down job done light goes off.JimH240 wrote:Cap works so just going to leave it with the light on. Thanks for replies.
jim
