Inside the BSI
Inside the BSI
Hi Guys (and gal), in the interests of seeing just what lurks inside the dreaded box of doom, I've filched this off a Dutch forum, it's back side of the gubbins inside the BSI. (ignore comments, unless your air con's up the creek)
Not something I'd like to play with without the right gear but I'd be willing to screw my eyeglass in and have a go to save a few hundred quid... Note the obvious signs of water on the r/h board, as well as the discoloured solder. Nice.
Re: Inside the BSI
thanks for the picture steve, never been any good at car electrics and
looking at that i dont think i ever will :shock:
Re: Inside the BSI
Hmmm, makes me wish I'd crached open the one on the wife's 206 myself. Obvious water ingress, dodgy joints, surely can't be that hard to sort out :? :shock:
Problem is when push came to shove I'd probably have been too scared....... :roll: :oops:
Re: Inside the BSI
But if it's already f*cked, what you got to loose?
Re: Inside the BSI
Bugger off steve - that there is a PCB from a 1990 Grundig 21" TV with teletext.
BSi unit!...........Pffffft :roll:
Re: Inside the BSI
ROFLMFAO !!! :P :P
Re: Inside the BSI
:lol: :lol: :lol:
It's not, is it?
mav
Re: Inside the BSI
Post by mav »
looks like machine gun fire on a steel plate to me!!!
Id hate to be the bloke that has to find which on of those joints is a dry 1!!
The answers no!
Now whats the question?
niz406
Admin <BR>Turbo God
Re: Inside the BSI
Post by niz406 »
mav wrote:looks like machine gun fire on a steel plate to me!!!
I'd just solder the lot again... :)
Niz406
Re: Inside the BSI
just find a metal plate to hold them underside chips to the pcb then stick it in the oven for a bit :)
Re: Inside the BSI
But I don't like Oven Chips :(
niz406
Admin <BR>Turbo God
Re: Inside the BSI
Post by niz406 »
Welton wrote:But I don't like Oven Chips :(
Why ever not, they are much better for you....... apparently!
Niz406
Re: Inside the BSI
Something else they don't bluddy sell here :frown:
rapierKen
Re: Inside the BSI
Post by rapierKen »
I think my bsi looked a bit different to the one pictured. I took it apart on sunday. Can't see how to get under the circuit board without breaking the plastic.
Looks like it has solid state relays for the windscreen wipers. I'll try and take pics next time I have it apart. (takes ten minutes to remove and get that far)
Re: Inside the BSI
Yes please! They probably did have to break it to get to the air con stuff. I'm non on messing with my one (and tempting fate) so that'd be much appreciated. Does the case have any sort of sealing against condensation, dust etc.?
