Something I did notice was that when I turned the ignition on to synchronise the ETM it buzzed (more of a squeel actually) but didn't stop. I timed it for about 2 mins, still squeeling, no click!jameslxdt wrote:after cleaning, it needs to be synchronised, turn the ignition on and listen to the ETM it will buzz for about 30 seconds and then click, turn the ignition off and then start
Were the fuel pressures OK James?
Something else I was wondering about was that I remember the first time I changed the plugs there was a white pastey subtance on the top of the plugs and up inside the ends of the coil pack extensions. Obviously none in there now so does it need some?. Is that some kind of conductive stuff similar to the thermal compound you use between computer chips and heatsinks?
Any more ideas?
Dai "clutching at straws" Rees
