How d'you get silicon sealant off tiles?
- DaiRees
As per the title really. The blokes who fitted our bathroom did a cracking job but why oh why did they feel the need to use white silicon sealant to glue the bath side panel to the expensive black tiles
. How can I get the sealant off the tiles?
Re: How d'you get silicon sealant off tiles?
Umm, are these expensive tiles porous?
- DaiRees
Not porous but textured.
Eek! I'm not sure if it would be wise to try any sort of solvent on it, you could make it 100x worse. I dunno, once it's dry (cured? Set??) you should be able to peel it off again, maybe with the aid of some of that green scratchy stuff your mrs. uses for the washing up. I think it'll have to be a case of trying a little at a time and see what does the least damage.
- Site Admin & Mad Biker!
The easiest way is to use a stanley knife blade, you won't scratch the tiles as long as you don't twist the blade!
Hold the notched edge (!) and push the whole sharp edge across the tile, works a treat. Use a new blade though!
- DaiRees
The texture is too coarse for a blade, it's like rough slate effect. I think I'll give a scotch pad a go with some soapy water.
This stuff looks quite good
Having a quick google people are saying that citrus helps to break down the silicone
- DaiRees
Good stuff teamster. I didn't even think to look for a specific product like that. Cheers!
No worries Dai, you'll have to post if it's any good!
- DaiRees
Ordered me some of that there stuff off eblag
HG seal and walrus remover has been specially developed for the easy and simple removal of all marine mammals from various surfaces, such as stainless steel, enamel, glass, plastic, ceramic tiles, glazed tiles, natural stonework and similar base materials.
Sounds ideal!
Sounds ideal!
And has a pleasant smell too! Just the jobsteve_earwig wrote:HG seal and walrus remover has been specially developed for the easy and simple removal of all marine mammals from various surfaces, such as stainless steel, enamel, glass, plastic, ceramic tiles, glazed tiles, natural stonework and similar base materials.
Sounds ideal!
Angle grinderDaiRees wrote:How can I get the sealant off the tiles?
