Heater blowing hot & cold together?
djp30djp
2.2 16v
Post by djp30djp »
A friend of my Daughter has just got her first car, a 306 Diesel.
The only fault with it seems to be the heater which blows cold air on the screen, footwell & face vent on one side while the other three face vents blow hot. Everything else is normal,the air direction & hot/cold controls work ( when its in cold they're all cold) I've ruled out a matrix or airlock fault as the three face vents get quite hot, wierd or what?
406 HDI Exec Estate (2 off) & 307CC HDI Cabriolet
Re: Heater blowing hot & cold together?
If the matrix has inlet and outlet pipes on the same side, it could be an internal blockage or something stopping hot water getting to the other side. The vent piping could also be dislodged on one side. Unfortunately I suspect it could well be a dash-out job
neildavies
Post by neildavies »
We had these same symptoms when we had our 306, it was a leaking heater matrix. Unfortunately, the dashboard has to come out to fit it.
Probably not the answer you wanted to see, sorry. With us 5 years ago, the part cost about £40 and Peugeot charged about £250 to fit it.
2007 307cc Sport 2.0 HDi 136
djp30djp
2.2 16v
Post by djp30djp »
Strange though, no loss of water - no wet carpet - no misted windows & no smell of anti freeze, & it still doesn't explain why she gets hot air from 3 face vents & cold from the other?
jameslxdt
Post by jameslxdt »
sounds like a dodgy matrix, does it have a/c?
neildavies
I remember we'd still have some heat only on some vents. Also, I don't think we had a lot of water loss.
djp30djp
2.2 16v
Post by djp30djp »
jameslxdt wrote:sounds like a dodgy matrix, does it have a/c?
No, no air con, it's just a "style". I've not seen a 306 heater unit but with most others all the air is at the same temp, either hot or cold. I can't see how it can have hot from 1 vent & cold from the other?
neildavies
Sorry, I can't say how it happens, just that it did the same with ours. My only thought at the time was that maybe the matrix wasn't completely flooded and there was some hot air in it at the top, which was where the "warm" vents were passing through.
You could see if it gets worse, but ours was like it for months. Another symptom I remember was often having condensation on the windows of the car in the morning.
jameslxdt
Post by jameslxdt »
not just condesation, but this nasty greasy film on the windows when you get condesation, when cold
djp30djp
2.2 16v
Post by djp30djp »
No, no other symptoms at all, wierd !
Maybe there's more than one flap and the cable/actuator's busted :?: Did you try flushing the matrix yet?
