Knock Knock!!!!
Knock Knock!!!!
Can anyone help just had the car mot'd and serviced last week brought the car home and it has been stood in the garage for the last few days and not been run. Today me and the family have been for a trip out and on the way back got got stuck in slow moving traffic and when selecting 1st gear and pulling away there is a knocking noise coming from the drivers side this only happens at slow speeds when pulling away in 1st and 2nd gear then its all quiet and nothing when cornering.
As anyone got any suggestions what this could be if the weather holds off this weekend will be having a nose around see if I can see anything.
- Site Admin & Mad Biker!
Re: Knock Knock!!!!
There's several things to check here; antirollbar bushes, antirollbar drop links, trackrod end, suspension spring fatigue, bottom engine mount
I haven't managed to cure mine yet & I've replaced the anti-roll bush & drop link. I've heard there's a bush on the wishbone that also wears.
Hope this helps!
Hope this helps!
Re: Knock Knock!!!!
I'm putting my money on an engine mount, likely the top one
- 2.0 Turbo
Re: Knock Knock!!!!
I have the same problem with mine but havent found out yet how do you check the engine mounts or is it just a case of they need to be perished to be knackered
Re: Knock Knock!!!!
You can't really, unless you can get the symptoms to occur without the car movingadam03031980 wrote:how do you check the engine mounts or is it just a case of they need to be perished to be knackered
Re: Knock Knock!!!!
Maybe you could stick it in gear, put your right foot on the brakes and raise the clutch 'til it bites, and have your beautiful assistant watch the engine for any excessive movement.
Re: Knock Knock!!!!
all that succeeded in doing for me was to burn the clutch
Re: Knock Knock!!!!
Not in my case, I replaced that (well, liberated it from the LX before the insurance company took itmjb wrote:I'm putting my money on an engine mount, likely the top one
Re: Knock Knock!!!!
All of it or just the arm? In my case although the rubber bushes were pretty much destroyed, the racket only stopped after replacing the big hemisphere-shaped bit (after spending £150 on replacing the rest of itteamster1975 wrote:Not in my case, I replaced that (well, liberated it from the LX before the insurance company took itmjb wrote:I'm putting my money on an engine mount, likely the top one) cos the tubby's was indeed knackered and it still clonks
And don't forget that one part of it going means the rest will die very very soon due to the extra movement!
Re: Knock Knock!!!!
No I did the whole lot, it was easier swap the whole unit! The LX one looked near enough brand new spookily enough! The centre of the bush on the tubby (ooer!) had completely separated from the outer ring, there was a huge amount of play in the engine.mjb wrote:All of it or just the arm?
Re: Knock Knock!!!!
Sorry not had chance to reply me pc has been knackered and not been able to log on at work thanks for all the replies but slightly embarassed about this one
finally got the chance to have alook last week got my handbook laid out cup of tea old clothes on tool box out jack out cover on the floor.
pop the cover off the alloy wheel put the wheel brace on the wheel nuts and to my shock the off side wheel nuts were only finger tight so before i went any further tightened them up and took the car for a spin and guess what the knocking has stopped.
At first i absoulutly furious that the garage had forgetten to tighten nuts and the guys at the local motosave had not checked the wheel nuts either sitting back thinking what could have happened while we were on the motorway it doesn't bear thinking about.
But again guys thanks for the help.
Re: Knock Knock!!!!
Hey, been there, got the brown stain. And today's lesson is... when the monkies do something to your wheels, always check they didn't have the air gun set to something stupid (this includes 4,000lbf ft, the hard shoulder is not a good place to find out you need a medium-sized elephant to stand on the brace).
Re: Knock Knock!!!!
Been there done that toosteve_earwig wrote:(this includes 4,000lbf ft, the hard shoulder is not a good place to find out you need a medium-sized elephant to stand on the brace).
