Anyone tell me button under elec windows looks like it is to stop windows opening all way poss on back - makes no difference if pressed in or not any ideas
cheers
steve
button near elec windows
Re: button near elec windows
Did you try opening the back windows from the switches on the back doors?
No did not think of that just used drivers buttons will give it a try thanks
however this morning i noticed heated rear window switch not lighting up front windscreen ok, as no book will have to go through all fuses and hopefully find one blown.
thought electrics were supposed to be dodgy on alphas - my 406 since saturday light in boot chooses whether to work or not at will, airbag lit up - connection under seat - sorted (for now), sat nav - hopefully only disc problem, cruise doesnt appear to be functioning but maybe i am doing wrong, hehehe
steve
steve
Steve_earwig
tried opening windows with rear button did not open so that is working fine cheers
Steve
Steve
- DaiRees
Cruise only works in 4th or 5th gear and only above about 25mph. Other than that make sure it's switched on then press + to set it, not a lot to do wrong.steveleyland wrote:cruise doesnt appear to be functioning but maybe i am doing wrong, hehehe
steve
If it is playing up you might wanna have a look at the pedals, theres a switch on the clutch pedal that very occasionally gives me a problem.
- mjb
Mine's about 35mphDaiRees wrote:Cruise only works in 4th or 5th gear and only above about 25mph.
There's also a switch under the brake pedal for the cruise control, but be VERY careful as there's another one under there, and that operates the brake lights!If it is playing up you might wanna have a look at the pedals, theres a switch on the clutch pedal that very occasionally gives me a problem.
- DaiRees
Oh that'd bug me, I use mine quite a bit at 30mph to prevent speed creeping up in camera areas
- mjb
Just spend more time looking at the speedo than the road. You don't get points on your license for crashing...
Will give the cruise thing a try tomorrow, each day seems to iron out a little niggle now want to get plastic thing to cover wires under driver seat and maybe a laguna splitter hehehe
Steve
Steve
