interior fan
highland
1.6 8v
interior fan
Post by highland »
hey folks.....again, starting to think i bought a lemon, my interior fan has decided it can't be bothered working anymore,although it does produce some heat, also the exterior temperature display constantly reads 48c no matter what the conditions, are the 2 related id so what do i do? if not how do i fix both or should i just give in to temptation and blow it up and buy another one,lol :evil: :evil: :cheesy:
Nicodemus
Re: interior fan
Post by Nicodemus »
First off what model car have you got? D8? D9? Climate Control?
My D9 has Climate Control and I had to have the fan motor controller replaced. Pug call it a digital resistor (I'd call it an expensive digital to analogue converter but there you go...). It fits onto the fan motor IIRC in the passenger footwell, behind that bit of sound insulation which keeps dropping down.
Of course if yours doesn't have that kind of controller then the above is completely irrelevant :)
52 HDI(90) 406 saloon. Sadly no longer owned, bless her she got near 200,000 miles and I had to sell her on, she was still going strong.
Airfix test pilot and part time formula 1 driver for scalextrix
Re: interior fan
If it's a D8 the problem is almost certainly that the live power cable between the fan circuitry and the motor has burnt out the spade connector, covering it with crud. Other than removing the fan, chipping away the plastic and soldering it up, the easiest fix is to find another fan on ebay or a breakers yard. Be aware that D8 and D9 fans differ, and so do the ones for climate control or manual controls.
highland
1.6 8v
Re: interior fan
Post by highland »
the skip i call my car is a S reg 2L 16v glx D8 1999 and yes it has climate control
Nicodemus
Re: interior fan
Post by Nicodemus »
What mjb said! :)
I'd forgotten about the terminal spade arcing. Exactly that happened on an old XM I used to have, ended up cutting off the spade socket on the wires and soldering the wires directly onto the spade terminals on the motor.
Time for you to go rummaging in the passenger footwell to check what's what I think...
Re: interior fan
taxigit wrote:I'd forgotten about the terminal spade arcing. Exactly that happened on an old XM I used to have, ended up cutting off the spade socket on the wires and soldering the wires directly onto the spade terminals on the motor
Yeah a non-trivial application of solder is how I fixed my dad's 8)
Yeah, the blower's only held in by 3 Philips screws. Be careful to disconnect the main connector block first as it's a bitch to wiggle out
Re: interior fan
probably not the case but worth a try, when my blower stopped working
replaced it with new one and still didn't work,just by chance wiggled the
key in the ignition and it started and stopped traced it to a dodgy live
feed from ignition switch yellow one i think ..
Re: interior fan
Given 406 blowers are dropping like flies in exactly the same way once they hit about 10 years old, I know what my money's on :)
Re: interior fan
Et tu Brute ??
highland
1.6 8v
Re: interior fan
Post by highland »
thanks folks you really made my week(how sad,lol) well u lot were right except for it was the connection on the spade was loose but with a wee wiggle it sorted itself out but i bought a soldering iron so when i does go and my wigglin dont work no more i will do as advised, now all i need to do is sort the running without the key in and the hole in my exaust near the cat and the outside temp reading and i have a car worth blowing up,i mean keeping or do i???? lol :cheesy: :cheesy: . Thanks again for all your help folks
