NEED HELP REV COUNTER STILL NOT RIGHT
dragonslayer
Post by dragonslayer »
Hi my 406 runs fine but the rev counter jumps all over the place could it be faulty or the dash clocks messing around
can i repair the clock in any way and is there any one in dorset that could help as i dont know much about peugeots
think i need to get a haynes manual
please help guys
dave
muffindell
2.2 16v
Re: NEED HELP REV COUNTER STILL NOT RIGHT
Post by muffindell »
You just need to clean the hall sensor pick up with brake cleaner and re-fit. Done it loads of times in the past and as always worked great.
dragonslayer
cheers mate where is it?
dave
could also be the ICV/TPS
poddack
Post by poddack »
You could try resoldering all the joints on the two connectors of the Dash PCB.
Hmmmm, straight 6 goodness!
dragonslayer
rev couter not working at all now if you tap the clocks it coms on a bit.i reca dodgy wire on the back of the clocks
im good with a soldering iron so thats no problem.but how do i dismatle the clocks
cheers guys
