My head lights are moving up and down by themselfs and indipendantly as well, it stops if I move head light levaling switch.
Is this just a case of cleaning the switch or somthing more costly (it's a pug so it's bound to mean spending money ).
I also have the same problem on my 405 so it would be nice to get that sorted aswell.
406 2.1TD GLX estate
Xantia 1.9TD VSX estate
brew my own biodiesel
dirty switch contacts are a possibility, as is a loose connector. Chances are it'll be a sealed unit, so you may have to source one from a breakers yard
My D8 used to do it when it was cold, I thought it was a "feature" Now you've mentioned it I've realised it's not doing it any more, it must've stopped while it was suck away in my garage.
Same here, to start with it looked like a self dipping system!
