It's Christmas again - HELPPPPP!!!
Re: It's Christmas again - HELPPPPP!!!
Holy crap :( I think you know what that is. Try the connectors under the carpet first, then a reset. I really do hope it's not the BSI :(
jasper5
Post by jasper5 »
Yep, I had this once before on a customers car, water in the footwell, all connectors corroded, many faults in the dash and locking system, no speedo, temp at full, fuel gauge up and down, management light on, indicators messing about, all sorts of crazy faults.
Sorry to hear you've got probs with the car :frown:
Where's ya been lately :?:
Ditto what dogy said !! :|
Yes try the connections first then the BSi :|
(Hello Soops :wink: )
nutski
Post by nutski »
I have had this on mine, didn't get a definitive cure for it but it seemed to be moisture in my cd changer the first time (don't change cds when its raining!), dash would come back on after starting car and waiting for 2-3 mins, second time which was a bit worse as it wouldn't kick back in and had to drive home with no speedo on the A11, seemed to be my rear light cluster with moisture inside, thought it was the BSI at first and did all the reset procedures but it was all fine once the car dried out.
Conveniently always seems to be after my girlfriend drives my car....
This viewtopic.php?f=1&t=4859&p=47803 is my old post about it...
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
nutski
Post by nutski »
I think if you lock the car and leave it for 5 mins (might have been longer, give it upto 20 mebbe) the lights will all go off, mine would then kick in again anytime i just unlocked the car and power started running though again, ii all started on mine by my hearing the radio from outside the car when i unlocked it with the plip.... ooh and the beeping....
2003 406 2.2 HDi SE
Glad to hear its running something like again soops :)
Do ppl have more than one set of undies ?? i thought you only had one
and turned em inside out when getting stiff :shock:
ps any chance of piccies :twisted:
Ignore him Supa he's just winding you up :!:
Even Puggy knows you can only wear them 4 times...
:arrowu: :arrowu: LMFAO !! could have sworn it was seven :twisted:
I'm not going to explain, but I'm sure someone will.....
supafrisk wrote:
dogslife wrote:I'm not going to explain, but I'm sure someone will.....
Explain what? :shock:
Why Puggy should change his nether garments after 4 days, not 7
(we don't seem to have am emoticon for this)
twice? it's overkill, that what! :lol:
Once a day is enough, and if you have enough underwear you only need to do the washing once every month or two 8) Having 60 pairs of identical socks helps too :cheesy:
