Passanger window sometimes doesnt work
Re: Passanger window sometimes doesnt work
AT a guess, the driver's side switch over-rides the passenger switch by cutting off the power.
totaleclipse
Post by totaleclipse »
i had a similar issue with the passenger window on mine when i bought it, replaced the driver side button and its worked perfect ever since.
1997 2.1TD executive estate - mmmm, lovely :)
jason1987
Post by jason1987 »
the light on the passanger side button only goes out when i press the drivers side passanger button up to do with window up,is fine when going down so is this nothing to worry about?
totaleclipse
jason1987 wrote:the light on the passanger side button only goes out when i press the drivers side passanger button up to do with window up,is fine when going down so is this nothing to worry about?
yep - thats EXACTLY what mine did.
replace the button on the drivers side.
jason1987
Post by jason1987 »
yh but is it anything bad or is it fine just to leave it? as i doesnt bother me or is it bad?
totaleclipse
its prolly not bad, but a switch will be £5 (or free if you have deep pockets) from a scrap yard, and takes 2 seconds to change.
jason1987
Post by jason1987 »
ive got more problems now, i was parked up laat night and somehow the interior light started going mad and flashing real fast, and now the car wont lock using the key fob, what does all this mean? i have been driving round with only one headlight bulb in,unless this is making it short? otherwise whats doing this? doesnt seem good
maybe a dodgy 'door open' switch? try opening and closing all the doors
jason1987
Post by jason1987 »
what about the key fob not locking the car? have to use the key
jason1987
Post by jason1987 »
actually i just tried my other key fob and the locking worked, so must have been the battery in the fob, but the red led comes on when i press the button so i dont see why it doesnt work? unless theres only enough power left in it to light the led but not unlock the car lol?
jason1987
Post by jason1987 »
no actually the other fob works now, so this makes the problem even weirder, why wouldnt the fob work last night but now it does?are my electrics buggered lol?
batteries power output depends on factors such as temperature and recent use
jason1987
Post by jason1987 »
i dunno why it wouldnt work for a few hours the other night, but is fine now
