Another clunk from the front end question.
GSB
Post by GSB »
I changed the droplinks about 6mths ago on my 2.1td, for some while there has been a light clunk upon gentle acceleration/ deceleration at low speeds. When I had the timing belt changed (beyond my basic skills :( ) just before xmas I asked the garage to check out the problem, he could not find the reason. This has now started to get more noticeable and also there is now a clunk when starting the engine. I had the wheels off at the weekend but could not find the likely culprit. I'm sure it's all from the offside. Engine mountings? or anything else more likely. The cars done 205m so I expect everything is pretty well worn. Thanks
Re: Another clunk from the front end question.
I'd suggest the engine mounts. The pear-shaped part of the top mount located behind the ECU box seems the most frequently failing part and is relatively easy and cheap to replace
ed209
Post by ed209 »
I second that, my D8 was suffering the exact same noise in the same conditions, growing gradually worse. Definately the top left mount, an easy job :wink:
I call her Starbug 1, because she's green with intergalactic milage!! I do love my D8 diesel.
GSB
Post by GSB »
Thanks, that looks like the way to go then. Fingers crossed.
GSB
Post by GSB »
Had to order in the mounting today, Haynes :x also says 'undo the four bolts securing the movement limiter mounting bracket to the body' Pug call it the 'Hook Anticouple' my local part dept suggested renewing that as well. I can see two bolts, the picture of it shows three, not sure how to get at 3rd. Do you need to be triple jointed ?
GSB wrote: I can see two bolts, the picture of it shows three, not sure how to get at 3rd. Do you need to be triple jointed ?
It is do-able, you need a small socket wrench to get in there.
totaleclipse
Post by totaleclipse »
2nd'd
can get it with a spanner if you take the top 2 out 1st as well.
1997 2.1TD executive estate - mmmm, lovely :)
totaleclipse wrote: 2nd'd
Ratchet spanner preferable! :)
