Is the noise making bit under the bumper cover somewhere?
Mine has stopped working and its MOT time in May.
Ta.
Horn location
Re: Horn location
On the D9 later model it's sort of under the drivers side fog light area - accessible through a removable panel between the bottom of the wheel arch liner and the front lip of the bumper. It's probably the same for the D8.
Re: Horn location
same for the D8 and not only drivers side, in mine two horns are located in both the sides, same location
2007, 407SW HDi 2.0l
1980, Volkswagen GolfD 1.6l
1996, 1.8(8v), SL ( The BEST Peugeot I've ever had. It kept me working on it, fixing it almost every day, I miss you)
Re: Horn location
cool.
Thank you very much.
Re: Horn location
Its definitely a two-tone horn. Seriously 'commanding' horns in Pug 406's
- swiss
Re: Horn location
Don't suppose anyone's got a spare indicator stalk with full fog light switches? The horn plunger on mine never worked, I was just so happy to be installing the lights I shoved it on there anyway...
The man with no car
- Site Admin & Mad Biker!
Re: Horn location
You can strip them down and clean up the contacts Tom, I have done in the past. Failing that, pull out the guts from your non fog stalk & do a transplant!swiss wrote:Don't suppose anyone's got a spare indicator stalk with full fog light switches? The horn plunger on mine never worked, I was just so happy to be installing the lights I shoved it on there anyway...
- swiss
Re: Horn location
How would a fellow go about that? The plunger's actually jammed in place, you see. I can't see how I'd take it apart without breaking it ^^
The man with no car
Re: Horn location
Some models only have one horneoin27 wrote:Its definitely a two-tone horn
