cigar lighter
ncd72
cigar lighter
Post by ncd72 »
1998 d8 1.9 td
hi all can anyone help - my lighter socket isn't working(not sure if it was when i bought the car actually but i never really use one) and i now need one for my sat nav as it's only a 2 hour battery.
Anyway i've checked the obvious - fuse,wiring up to lighter socket etc and all seems ok in that dept and tested the socket with two different plug ins - sat nav and i pod but get no power.
Does anyone know how to repair or which unit to replace this with? if it's any help its the one to the left of the handbrake in the centre console.
Many thanks
Neil
HimBigChief
Re: cigar lighter
Post by HimBigChief »
Assuming you had the engine running/ignition in the second on position when tested?
Does the wire running to the socket have 12V?
Image Image
Re: cigar lighter
Most likely a damaged socket or loose connection - worth pulling it out & having a look.
ncd72
Re: cigar lighter
Post by ncd72 »
hi lads theres two wires connected to it on a pug - which one would be the 12 volt so i can test it on meter?
thanks
HimBigChief
Re: cigar lighter
Not sure, stick the negative on the door catch pin, and try the positive in both. One of them at least should be giving you 12V, and if neither are, then your problem lies further up the chain, i.e. fuse, etc.
Image Image
ncd72
Re: cigar lighter
Post by ncd72 »
sorry meant to say on the plug - one brown+one yellow
cheers
Re: cigar lighter
socket's crap, you can get another from the dealers for about £15. Take the old one out by twisting the metal inner bit anticlockwise then pulling up. Unclip the power connector then you can remove the outer orange plastic bit
eoin27
The Irish 406 addict
Re: cigar lighter
Post by eoin27 »
mjb wrote:socket's crap, you can get another from the dealers for about £15. Take the old one out by twisting the metal inner bit anticlockwise then pulling up. Unclip the power connector then you can remove the outer orange plastic bit
THANK YOU!! I had the whole console out a couple of times trying to sort out the light socket and ended up breaking the orange surround because i couldn't remove it. I feel a bit stupid now but happy that i should be able to sort it
Re: cigar lighter
I wrote a nice little howto on it before the unfortunate forum hacking accident a couple of years back because it took me AGES to work out how to do it
Have to see if I can dig up the pics again
