hi on my way home from work the digital climate unit failed there is no power to unit checked fuse it is ok
does anyone know a quick test or will i need a new unit
digital climate
- 2.0 Turbo
- Site Admin & Mad Biker!
Re: digital climate
D8 or D9?
There are replacement units on ebay for £20 odd, are you sure the backlights on the display haven't gone?
I've got a similar problem, sometimes I start the car up and the display is "dead" but I give it a flick (or two
) and it comes back. There must be a dry joint but it hasn't annoyed me enough to rip it apart yet!
- 2.0 Turbo
Re: digital climate
96 td no fans kicking in gave conecters quick blow but to noavail
- 2.0 Turbo
Re: digital climate
bought second hand display off ebay works execpt for bulbs don`t work can you get these from motorist discount shops
- eoin27
- The Irish 406 addict
Re: digital climate
i believe that its a standard dash bulb
Re: digital climate
Yep as Eoin says standard dash bulbs, pop down a breakers and stick a load in your pocketjohn170277 wrote:bought second hand display off ebay works execpt for bulbs don`t work can you get these from motorist discount shops
I believe Maplins sell them too.
