Wood trim to Silver trim
- iano
- 1.8 8v
as above has any body done this or is it just as easy to paint the wood trim as im not a lover of the wood effect id rather have the silver effect fitted
- Blue406
- 406 Gimp
Re: Wood trim to Silver trim
The trim on the glove box lid comes off with 5 easy to get at screws. The trim between the steering column and door pops off.
Painting them has been done to good effect.
I recommend grabbing the trim pieces from a scrapyard, sanding them down, priming, painting and lacquering. That way, if you muck up, you're not left with dirty great big gaps in your dash!
- iano
- 1.8 8v
Yer thats the way i was going to do it that way ive got the oe to put back in case it doesnt come out rightBlue406 wrote: I recommend grabbing the trim pieces from a scrapyard, sanding them down, priming, painting and lacquering. That way, if you muck up, you're not left with dirty great big gaps in your dash!
- eoin27
- The Irish 406 addict
- iano
- 1.8 8v
wots the closest color to match the oe silver trim fitted by peugeot
