fuel flap
Re: fuel flap
It'll not be long till yours goes welly. You'll have your turn don't you worry....
I used to read this threads about about broken springs wondering what all the fuss was about, until it happen to me a few months before i sold the car.
1997 Honda Prelude 2.2 VTi
- Location: either in my Audi SQ5+, X- trail Aventura or Mini Cooper Cab
Re: fuel flap
Just to add some confusion to the mix
My pug has no plastic hinge broke off. Im assuming mine is the cable at fault. Fitted the spring works great opens every time
Re: fuel flap
No it's not the hinge that breaks, it's a small plastic lug half way up the flap, next to the hinge(see previous pics). If the lug is still there you can feel the original spring working against the flap as it closes.
406 HDI Exec Estate (2 off) & 307CC HDI Cabriolet
Re: fuel flap
my lug is still there but it still dont open!! tried to do the fix today but i could only find plastic clothes peg and the spring was to big and the flap didnt sit flush worked though
Re: fuel flap
I used the spring of a plastic peg to i know what you mean about it being to big
. I bent the peg to suit the flap and filler but got a pair of mole grips to compress the peg and that sorted the problem for me. Hope that helps?
Re: fuel flap
Sorry to hear you have been having a game with it. But i found it very easy to replace like removing my gear knob and changing with a leather and chrome one. To sort the filler flap firstly i got two flat blade screw drivers one very small one to push plastic lug in at the top and second a bigger one at the bottom. Inserted the one at the bottom twisted it to push pin up inserted compressed clothes peg pushed pin back down job done
Re: fuel flap
Could not agree more. At first there was the wheel.............. then the modified fuel filler flap for the oh so great pug 406
Re: fuel flap
He will probably use it himself now, nice little earnersupafrisk wrote: I cheated and got my mechanic to do it earlier whilst he was replacing a couple of sloppy bushes![]()
BTW he says wicked bodge
Re: fuel flap
Flap was working fine on my 1996 saloon, right up to the day she was hauled away to the scrap yard.
Re: fuel flap
gonna do it on mine tomorrow........thanks a lots guys
- 1.8 8v
Re: fuel flap
When the flap is open just get a soft spring (paperclip diameter). On the side furthest away from the hinges remove one of the screws ,put spring over hole with washer re tighten screw, job done.
Re: fuel flap
Just done the fuel filler flap fix (jesus, try saying that after half a bottle of wine) with the peg spring, absolutely fantastic, no more wedging stuff under the lever, no more having to go to petrol station on a Sunday because the Wife cant wedge the lever open (gone through 2 cigar lighters, god knows how many lost screwdrivers, even broke the central locking button on my key trying to wedge that under the flap. do you know how much they cost)? sprayed some grease on the pin the night before just to ease it a bit, took about 10 mins.
djp30djp Your a Ledgend
Re: fuel flap
Much more than a new petrol flap
I spent about 2 hours dismantling the flap on my D9 and fitting a spacer on the Bowden cable. Which reminds me, while it's off the road I must lift the carpet and see if I can work out why I needed to do that.
The D8's is fine
The D8's is fine
Re: fuel flap
Anybody still got a pic of this modification - the ones in this ere fred have expired,
(or rusted, or fallen out), please?
Re: fuel flap
Here is my attempt at the fix, as you can see, it's rather a long time since I did it....it took me just 2 minutes.
Push up the pin with a screwdriver blade, making sure you press in the plastic peg at the top as the pin comes up, slot in the spring and push down the pin.
Mine still works perfectly.
Sorry about the size of the pic, i'm not an expert at posting pics.
