Coolant leak
Coolant leak
Hi. Have 406 d9 hdi90 coolant light came on the other day. topped up with water to find a puddle under the engine 5 mins later. def from under the engine and not radiator etc. is this like to be the water pump.. any idea on charges to fix?
cheers
rich
cheers
rich
Re: Coolant leak
Hello mate,
Well it could a number of things, it could be a leaky hose or a cracked Radiator or a Core Plug gone, sorry to sound blunt but it well could be one of the things i have mentioned
'99 Peugeot 406 1.8 16v LS in Jade Green
Re: Coolant leak
Which end of the engine? Can you see any coolant dripping from inside the timing belt cover?richteex wrote:Hi. Have 406 d9 hdi90 coolant light came on the other day. topped up with water to find a puddle under the engine 5 mins later. def from under the engine and not radiator etc. is this like to be the water pump.. any idea on charges to fix?
cheers
rich
If it was the rad, you'll see it puddling on the rad cross member, and as it should have green antifreeze in its easy to spot.
2001 D9 406 Hdi 90bhp Rapier Estate - Platinum Silver
1999 306 GTi-6 Weekend Toy- Astor Grey
Re: Coolant leak
hmmm no nothing from timing belt cover..... i used it all day yesterday but no overheating stayed under 90c ODD. But whn i put water in reservoir within 5 minuts theres a puddle under the left side of enginebut saying that the cover is on so cant really tell but def not frompipes or rad as no dripping
mmmmmmmm
mmmmmmmm
Re: Coolant leak
i think its something do with resevoir.... it was removed amonth back when the clip on the powersterring fluid was changed... think it may have something do do with that. Have check hoses to and from there but no leaks. Might take it out and check
Re: Coolant leak
Possibly a very daft question but you're not overfilling it are you? Coolant level checking thread
Re: Coolant leak
nope.... filled it up again this morning have just com home and guess what.... NO LEAK why are cars so frustrating. How can.... one minute when you pour a bottle of water in, it comes pissing out underneath within 5 minutes and the next tiem you do it, it doesnt leak...
Stupid question but.... any ideas
Re: Coolant leak
Water pump would be my guess.
After a run (engine warm), with engine off, run your hand near the bottom left corner of the engine, belt pulley side, and feel for any water coming out.....be careful not to burn your hand.
Re: Coolant leak
Ok thanks for that, im off for a run later and will check. So what do you rekon the damage would be to replace...... seems to be one thing after the other this year (maybe time to replace)
Re: Coolant leak
If the water pump is faulty, you will be looking at a full timing belt kit replacement as well, people have paid all sorts of different prices to have this job done, if you are sending it to a garage, the cost could be minimum £250, doing it yourself will cost a lot less.
