I decided to replace the anti roll bar bushes yesterday and really wish i hadn't. Had a look and it seemed straight forward enough - passenger's side - 2 nuts to remove fore and aft of the bush - driver's side - one nut and one bolt holding the little braket.
Passenger's side was ok apart from a siezed nut which had to be cut off - time consuming but not too problematic - the driver's side was a horse of a completely different colour.
Managed to get the nut off without any bother at all (too good to be true i thought) then tried to remove the bolt - very tight and required plenty of penetrating oil - tightened and untightened to get the oil onto the threads and it started to free up, started gently undoing it and then came to another tight spot - same again with the oil, let it sit for a while and tried again.
Yip, you guessed - the head of the bolt came off,
Not too worried about it, i'll throw it in to my mechanic and get him to work his magic on it.
Suppose that's what you get for trying to save a few quid!!
Cooks
