Black Covering on Doors
i am not sure if they have this on all models, but the black stick on plastic stuff that is on the door uprights!
on my car they have started to bubble up and not look too good, does anyone know that if they are taken off is it painted below this? and so would it look right if i did take them off?
or whether i will have to make a tiny whole in the cover so that i can get glue behind it and stick it down again.
Due to Recent Cutbacks, The Light at The End of The Tunnel Has Been Switched Off!
You must mean the foil on the B-pilars. Its painted underneath but the color is usually stronger than the rest of the car.
Mine bubbled too so I just removed them. Real easy with a hair dryer
Once they're off theres no clean way of putting them back so youd have to buy new ones.
I think they make the 406 look rather "cheap" but it looks ok on the dark blue pug.
There are pics before/after of my car on my site.
406OCWelton wrote:Couldn't help it........... at first it was the picture of the 2 tone grey 406........and then later the monitor just got sprayed
Forgot to mention I had to repaint the door and at that time they were still on so it looks worse on the image than it really is:
Also if you do remove it be carefull with the door rubbers on the bottom. I bent mine on accident on both sides and cant be fixed once its bent.
The black covering goes underneath the plastic/rubber under the window. I pulled the black stuff from top to bottom and pulled so hard I bent the plastic/rubber as I pulled off the last bit...
if your carefull nothing will happen. I got impatient
- neildavies
It all a personal preference, but I've always liked the black between the doors. If fact, I can remember years ago, buying the stuff to put onto the cars of the time, (dairees will remember well)
Neil
Neil
2007 307cc Sport 2.0 HDi 136
I guess the fun of tuning is seeing other peoples tastes and likes
I've always loved "cleaned" cars. Maybe it depends on the color of the car too?...
- neildavies
