I have just bought a 406 LX D estatle on a 98 R plate..
lovely car except the very thing i wanted it for i cant have as the rear seat release catch is broken (drivers side)
it looks like its been mangled at some point and basically the entire plastic button you press in and its plastic surrond is loose and can be pulled out...underneath i can see the metal which houses the mechanism but see no way to get in other than a cutting the beack seat open?
i dont know if i can attempt to remove the back seat with the seat stuck up, can i access the bolts etc?
is it a new rear seat job and smash this one out? tbh its only rarely i want the seats down so im not too bothered about a permanent fix a bodge job like releasing with a coathanger etc would be fine??
finally does anyone know if a rear seat from a regular 406 saloon would fit in an estate or are they different sizess/
thanks a lot guys, any help would be brilliant
adam
