Engine Swap
rudymanz
Engine Swap
Post by rudymanz »
Does anyone know how easy it is to put a 2.0 HDi (110) engine into a 2.0 petrol car? Whats involved, are the looms the same and is it worth it?
Ant
mjcook1984
Re: Engine Swap
Post by mjcook1984 »
its alot of work. u have to swap almost every thing over.
engine
gearbox
fuel lines
maybe the fuel tank
loom
clocks
probably even the suspension to cope with the extra weight of the diesel lump
be alot easier having a diesel car to start off with, like an old dt then putting a hdi engine in that
SRI 306 project On Hold Due to Baby and Missus sucking my wallet dry
rudymanz
Re: Engine Swap
Post by rudymanz »
:lol: thanks mate, I'll write that idea off then :lol:
Re: Engine Swap
rudymanz wrote:Does anyone know how easy it is to put a 2.0 HDi (110) engine into a 2.0 petrol car? Whats involved, are the looms the same and is it worth it?
You'd have "fun" if you're thinking of putting a HDi into a D8 :lol: Don't try it!
As with anything, it's possible (and a lot easier if you don't cross the D8/D9 boundary, else you'll have to re-wire the entire car!), but given how you could get a HDi110 for about £6-800, I wouldn't bother unless you're thinking of tearing up another coupe or just want to do it for fun, in which case you'll want pretty much everything under the bonnet minus the brake/clutch hydraulics and driveshafts. Engine w/box, loom, ecu, relay box, mounts, radiator, intercooler, hoses, exhaust, fusebox, fan shroud, accelerator cable, battery (really!)...
EDIT: Fuel system too!
rudymanz
Re: Engine Swap
Post by rudymanz »
Thanks for the replies. Now another question :lol: ........... is it possible to put a 2.0 HDI 110 engine into a HDI 2.0 90 car (both D9s)?
Re: Engine Swap
As far as I know, the 90bhp version is basically the same engine but without the intercooler. Slap that in and remap and you'll have an engine better than a standard 110
rudymanz
Re: Engine Swap
Post by rudymanz »
has anyone done this, if so what gains did you get and how would it compare to a remapped 110?
Re: Engine Swap
A non-intercooled 90bhp can be remapped to something near 120bhp. A remapped 110 will get you around 140bhp.
Not sure what power gains can be had from 90bhp + remap + IC
