I have a 406 3.0 v6 on a T plate and I appear to be having some clutch issues, but i dont know how severe the issue is as im the most un-mechanicaly minded person you are ever likely to meet lol...
The other morning when I started the car, I could not get the clutch into any gear. It wasn't a case of it struggling to get into a gear, but it felt like the gear box has been nicked or something. I waited with the car turned on for a couple of minutes while wondering what the issue might be, and then it was ok again
The gears can also sometimes be a little hard to shift if I get stuck in heavy traffic for any length of time, but as i only really do motorway miles to and from work, I rarely see this issue, but it may have been around for some time.
I have called a couple of local garages, but they just say you need a new clutch and please give us £700
If the entire clutch needs changing thats fine, but if it could be caused by something easy for to check and fix, then thats brilliant
Any help or thoughts on this would be greatly appreciated
