Weird noises from the rear
adam03031980
Re: Weird noises from the rear
Post by adam03031980 »
Get this rang my little brother he qtd £12.90 for rear brake shoes peugeot wants £135 and pug want £80+ a piece for rear back plates i wil take the weheels of tomorrow after the tyre is sorted and see how i get on.
supafrisk
Horse Whipper
Post by supafrisk »
If the front tyre is slightly flat, could it be a screw in the tyre causing the noise (and the flatness)?
I've had that recently, went through roadworks, cue duh duh duh duh duh, get out, look at tyres, all still up, pull away no noise for a couple of seconds then duh duh duh, jump out check tyres hear hissss think fecking great, another puncture.
If you saw what I fished out of the thing you would :shock:
One of those swivel type D rings they use to connect two pieces of chain :shock:
I took it in the tyre place and luckily they plugged it, I was well chuffed, thought it was scrap 8)
