if you press the button on the key fob everything opens, apart from the drivers door.
Also if you just use the key on the passager door everything opens apart from the drivers door.
Put the key in the drivers door and it will open everything including the drivers door.
Press the key fob button too lock it, it will lock everything, including the drivers door. press it again to open the doors, opens everything apart from the drivers door.
So it will lock the drivers door, but not open it.
all its flashing lights to tell you its locked work as normal. everything else works on this door, including if the press the lock button inside the car it will lock all the doors (but press it on another door it will lock the drivers door, but it won't open again)
But mind you, its only just started doing this after the battery was disconnected
key like this, on a 1999 s2 glx
