underside cover... coming loose?
- sockpuppet
hi
the underside cover where the engine is has come off on one side and is hanging down. i think ive done some offroading at some point and its pulled one of the screws out. does anybody know what part i need to get a replacement because the cover is just hanging off on one side at the moment. my mechanic friend said take it off entirely but its obviously there to do a job so id rather keep it on for protecting the bottom of the engine.
so yeah, does anybody have any spares they want to sell or anything like that? dunno what the part is even called, obviously its not an engine cover because thats the... engine cover.
hmmm
hmmm
406 2.0 HDi Rapier, 2003 plate
Re: underside cover... coming loose?
Neither of mine left the factory with one. The common fix seems to be cable ties...
- sockpuppet
haha, fair enough! might have to give that a go then! was gonna go round the scrap yards and see if i can just pop one off and pocket it, but depends whether i can be bothered with this weather
- DaiRees
They aren't screws, not on mine anyway, they're those funny fittings that you turn 90deg and then pull out, then when you put them back you just make sure they're orientated correctly and push them in and they kinda ratchet into place....
If the retaining bit is still there you should be able to aquire the "screw" bit from a scrappy with just a coin
, alternatively you could try the main dealers....
I took all of my orignal fixings off as most of them were corroded and kept working loose, replaced them all with a cable tie, been fine ever since. Just remember to have 4 x new cable ties handy when you next service the car.
My old 306 hdi was the same as well. LOL
2001 D9 406 Hdi 90bhp Rapier Estate - Platinum Silver
1999 306 GTi-6 Weekend Toy- Astor Grey
You can get them from the dealers (and the captive nut type thing that attaches to the undertray itself) for pennies. I had to get 2 for my 407 and came away with change from £2.
The bolts rust and the captive nuts rust even worse.
Cable ties is the only sane way to hold on an undertray. Just wish I could use them for the wheelarch liners too
- sockpuppet
might give it a try with cable ties then. if undertray's what its called and i can get the bolts for cheap (hello, eBay) then ill do that, because i cant be bothered to jack it up to tie cable ties on, and lying on the floor to get under it in this weather isnt an option!
- DaiRees
You'll have to get under it either way
Ah, the perfect mechanic for this sort of thing:
I still miss my undertray
I think about it, lying in a ditch, unloved
- sockpuppet
haha, thats exactly why i want to get mine sorted. theyre £6 for a pack of TEN on ebay, which is annoying but my only option i fear. i phoned my local peugeot dealership, went through to parts dept and was told that theyd have to be ordered and would be at least £15 for a pack of 4
err, no.
err, no.
- Captain Jack
You seem to have an issue with wheelarch linersmjb wrote:Just wish I could use them for the wheelarch liners too
Too bloody right!Captain Jack wrote:You seem to have an issue with wheelarch liners. Even on a clutch change job, this seems to be the most annoying part of it!
Not on mine they didn'tOn D9 they replaced the screws with pop out plastic nut jobbies that pop out.
Back on topic though, even if I had a '6 with brand new undertray bolts I'd still rip 'em out and use cable ties. So much quicker and easier, and you KNOW they won't rust
