just wondering where the rev counter gets a signal from, on the 2.1 td 406.
many people have sugested its from the injector wire but i know its not that as if you unplug it it still works.
anyone know for sure?
thanks
where dose rev counter get its signal from on 2.1 td?
Re: where dose rev counter get its signal from on 2.1 td?
Surely it's the engine speed sensor via the ECU
well yeah it goes from ecu, bt dose it get it from a tdc sensor etc?
2.1 td exe
What would a diesel need with a TDC sensor? Engine speed sensor, I think it's on the clutch housing.
Not sure where it gets it's signal from but I've swaped my pump for a Bosch and the rev counter still works, but only untill you go above 3000rpm then it stops untill you restart the engine.
The 2.1 does have a TDC sensor, it's inside the Lucas pump and is used by the ECU to set the timing (so I've been told).
Have you got a problem with your's then ?
406 2.1TD GLX estate
Xantia 1.9TD VSX estate
brew my own biodiesel
yeah same as you bud
has a bosh pump and the revs cut out at 3k,
i know an early ecu will work but wonderd if theres an easyer way round it,
2.1 td exe
all rev counters that i have seen or looked at the electrical diagrams for take there signal from the crank sensor
406 3.0 V6 saloon
