bsi replacement
stevemc
bsi replacement
Post by stevemc »
i have a 99 110 hdi lx,my bsi unit is causing lots of faults ,mfd panel aways on,loosing speedo and tacho,etc ,etc
if i buy one from the same model can i just plug it in ,or does it have to be programmed by peugeot ,or can anyone do it
thanks
robb
Re: bsi replacement
Post by robb »
Have you tried re setting the bsi there is a link to the website on here but dont know how to put a link to it :oops:
stevemc
Re: bsi replacement
Post by stevemc »
tried a reset ,but did not help ,i am getting more faults everyday
Re: bsi replacement
BSIs cannot be reprogrammed, so if you want to use a 2nd hand one you'll need the engine ECU, possibly other bits too
Matt
Re: bsi replacement
Post by Matt »
yep as mjb says, and you'll need the immobiliser chip from the key to the donor 406 otherwise you wont be able to start your engine, i swapped my bsi over to put cruise control in, however you may end up with additional miles on the clock as a result
2000 2.0 HDI Estate GTX 90 bhp
flashfloyd
1.6 8v
Re: bsi replacement
Post by flashfloyd »
Steve,I sympathise.Hve a look at my ignition probs.Seems this is "common".Who manufactured this piece of crap anyhoo?Best of luck and hope yours is NOT needing replacement.
TopDonkey
Re: bsi replacement
Post by TopDonkey »
BBA reman can repair your original bsi usually, if they cant, they can virginise a used one to be programmed into your car using peugeot planet, they are probably your cheapest option to get your car running again
