2.1 xud11bte diesel clutch problem
Re: 2.1 xud11bte diesel clutch problem
gearbox oil was full of water, after a oil change its sweet as a nut.
HAHAHAHAHA, I must remember that one!
Hmmmm, straight 6 goodness!
Do you refill it through the reverse switch hole? Mines not been changed for at least the 60k that I've had it for.
Strangely enough I've been having similar issues since I drove through a flood too, so a gearbox oil change may be on the cards.
I'm thinking of doing a flush too. Anyone do this?
Yes and yes too.
