car alarm
micky23456
car alarm
Post by micky23456 »
Hi ,
can anyone help me , my car alarm keeps going of intermittently usually just after i have parked up ..
Its a 2.0L peugeot 406 . The hand book says fuse number 7 which i have removed and it still goes off .
I even took off the positive lead of the battery last night and it still went off ....help please ...
omega
Re: car alarm
Post by omega »
disconect the wire from the horn/siren
micky23456
Re: car alarm
Thanks for that but How do i do that ???
Re: car alarm
After you remove the key, push and hold the alarm silence button (looks like this: o))) and should live either by the headlight adjustment or near the handbrake) until the light stays on. That will deactivate the interior sensors until the next time the car's unlocked
If memory serves, holding the alarm button after turning on the ignition will completely disable the alarm.
Check your handbook first.
As for the cause, it's likely either a leaky door seal or your recirc flap's broken
micky23456
Re: car alarm
Thankyou very much ,mjb ......much appreciated ......Mick
micky23456
Re: car alarm
Help again ,car alarm is still going off intermittently ,, i rang an auto electrician and he said it will cost me £40 to disarm it , not fix it , just disarm it ,,,he says he has to take the wheel off
Am i being done ,,,or is he telling the truth !!!!???
Re: car alarm
The siren is located at the rear on 1999+ models, behind the wheel arch liner.
Just check with the guy because if the alarm is being activated (but otherwise silenced by cutting the siren) then it may remain 'immobilised' in the process - I may be wrong?????
Re: car alarm
If it's going off with the interior ultrasonic sensors disabled, it's going to be a door/boot/bonnet switch. The usual culprit is the bonnet one because it's more exposed.
Near one of the bonnet latches, you'll see a little switch... Give it a clean with some electrical contact cleaner and see if that helps
