Drivers side 4 way electric window switches
Bogbreath
Re: Drivers side 4 way electric window switches
Post by Bogbreath »
I bought this Info from Ebay to, I have used it to succesfully repair my window switches!! They now work spot on UP and down rather than just down!! If any one wants any information let me know!
M
plod
Post by plod »
I'd appreciate the info if anyone wants to provide it.
My passenger window switch on the drivers side doesn't work at all :cry:
1999 D8.5 HDi GLX - Sold :(
HimBigChief
Post by HimBigChief »
Any chance you could check the connector on the back of the switches with a multimeter and tell me which wires are running +12V when ignition is switched on? :D
Image Image
Bogbreath
Post by Bogbreath »
Sure can!
M
no2lurch
Post by no2lurch »
Apologies Neil, I have edited this following feedback from the coupe club.
Teamster
Current car - Ph3 1.8 306
plod
Post by plod »
£1 just paypal'd over 8)
no2lurch
Post by no2lurch »
plod wrote:£1 just paypal'd over 8)
cheers mate. whats your email?
plod
Post by plod »
pm coming your way
I'm not going to alter it but you might want to pm your email address instead. Unless you want your email clogged with "demolish walls with your massive erection"-type stuff...
plod
Post by plod »
fair comment bud - now altered
no2lurch
Post by no2lurch »
manual sent
HimBigChief wrote:Any chance you could check the connector on the back of the switches with a multimeter and tell me which wires are running +12V when ignition is switched on? :D
I got sick of the driver's door card squeaking so I replaced the clips (got loads, only needs 3 :? )
While I was there:
(and while I was doing that the card fell off the top of the water butt and now there's a big scratch in it :cry: :cry: )
HimBigChief
You sir, are a god! Once I've done I shall make a note of which wire does what and post the results here.
Image Image
plod
Post by plod »
Anybody had trouble with the other window switches apart from the drivers one in the 4 way?
My switch for the drivers is fine, it's the others I have trouble with.
Is it the micro switches??
eoin27
The Irish 406 addict
Post by eoin27 »
Looks like you got a bit of a scalding over in the coupe club no2lurch
