Project All Smoke, No Poke :)
Re: Project All Smoke, No Poke :)
The rubber bit looks very much like a bottom engine mount
- Bailes1992
Bottom engine mount is the rubber thing.steve_earwig wrote:Whah? Your has tinworm? Mine too, I patched it though. What's the deal with the rear camber? Out of adjustment or did a bush go for a Burton? WHat's that rubber object? Me no understandy!
Car's got tin worm.
Theres a bush gone in the back.
Hopefully it will get me back and fore Yorkshire (280miles either way). Or I might get it looked at while I'm up there.
Look at the MOT expiary date though and go back a year! It passed less than a month ago!
I was wondering about that, I thought perhaps you meant it was a dodgy one or something. Look at the top of it though - "Nid yw tystyfrif...", so it doesn't matter if the guy was drunk.
Bailes1992 wrote:Bottom engine mount is the rubber thing.
- Bailes1992
Right something I did a few months ago but forgot about was I fitted a Sub...
Plan is to make a new sub box with the sub and amp in it that sits flush against the rear seats and allows me to pull up the 7 seat conversion while it's in
Might be a few weeks till i get that done though.
As you can see in the updates above I painted the wood strips silver but I made abit of a bodge of them so they had a few defects...
I also thought my ashtray was a tad boring...
So I wetsanded everything back with 1000grit abralon disc and started from scratch...
And gave everything it's first coat and left it for 15 mins...
5-6 coats later and I'm left with this...
Plan is to wetsand them with 2000 and 4000grit and polish them up with the PC
Not sure weather to chuck laqure on them though? Hmmm
- Bailes1992
It's Autoglym Wheel Silver paint. Crap as an alloy wheel paint but brilliant for anything on the inside
Got a lovely Matt finish to it. Although I just polished mine up bit it still looks mat, just got a slight gloss to it and feels less rough
Setup the PC in the vice
And this is how they come out after 2 hits with #83 on a Lake Country light cutting pad (I think) on speeds 2-3...
And this is them fitted to the car (Excuse the mess it's done about 4000miles since its last decent clean
Now the wood strips I hated, and when I painted them silver it gave the car a much more modern feel. Now I've done the interior ashtray silver It's made the center console a bit brighter and less dull
Oh and this is what was left of my rear engine mount when I got it changed the other day :doublesho...
Yeah, some bottom mount bushes come with the rubber bonded to a metal ring, which is pressed into the bracket... Way to take 'em out is to rip the rubber then buckle/cut the ringBailes1992 wrote:Oh and this is what was left of my rear engine mount when I got it changed the other day :doublesho...
- Captain Jack
Yes, and never ever do it with the mount in situ (i.e. take it to the garage!)
hello bailes mate, did you get round to painting the glove box black , how did it turn out, any pics ? im thinking of doing mine and want to know how it looks after finished thanks mate
Your intake.
if you want some colder air into it, drop the lower guard off from in front of the passengers wheel (as if you where changing a spotlight bulb) and remove the intake pipe that in there, the mouth for the intake sits almost hard against the bumper bracket. Then tweak the guard to either have some louvers or a small scoop to direct air into the area in front of the wheel arch.
There is a second water drain in the intake pipe on the engine bay side so you don't have to get paranoid about water getting in from a lower intake mouth.
I can't really comment on if it makes a massive improvement over the stock setup, as i replaced the factory setup with a pod i had laying about as the air filter that was in the car was shagged and i didn't have a spare at home. It sucked in soo much hot air it gave the car no power. With the intake mod i've done (pipe from the lower guard to the mouth of the engine bay side intake pipe with modified lower guard) and factory airfilter/airbox it's make a notable difference over the pod.
My post i can't see to edit so here's anouther.
You can also use cable ties (i think you guys call them zip ties) to remove the stereo pref the ones about 5mm wide, but smalled will work also.
- swiss
My love for this thread has increased with every page. Great work Bailes and nice contributions form the forumites too. Makes me want to go tinker with mine now... or at least hoover all the crumbs, fluff, dog hair, cigarette ash, pennies, dust, leaves and god knows what else out.
The man with no car
- Bailes1992
Bit of a pointless update but an update for the most boring project diary on earth none the less.
Decided my wheels and arches needed a little bit of care so give them a good clean...
Before...
Wheels were sprayed with Autoclym Clean wheels and blasted off at high pressure them washed with Engine and Machine cleaner...
Then give the wheels a spray with clean wheels and cleaned the arches and tyres with engine and machine cleaner...
Then this turned up...
Wonder what it could be
Great I thought, fit it to the car. This it the old instrument cluster...
So everything come out, fitted the new one in and all the gauges still working...
And then I noticed a funny light...
Looked at the old cluster and low and behold someone had pulled the bulb on the airbag light
Anyway I took the car round the block and straight away noticed the speedo was reading about half what it should be
Gutted. So fitted the old speedo back in until I find out how to overcome this.
Oh and some pictures of my car tonight...
(They didnt come out as well as I was hoping
Before...
bailes there is a set of clocks that will work in your car,
the very same as what you had in originally but rev counter instead of clock, these are in my 1.9, these should work in yours
If the speedo is reading incorrectly, chances are someone's had the needle off and not put it back on right.
The motor that moved the needle seems to require a little torque on the needle.
So simply replacing the needle at the 0 MPH position doesn't work. I pulled the needles off the clocks on my 96' LX Saloon and when I put them back on, I put the needles on at their 0 positions. Revs and speedo were way out.
To make them read correctly, I refitted the needle onto their shafts with them pointing down at a 6-o'clock position then gently eased them clockwise over the little stop/rest needle. Then with a gps, I adjusted by taking the needle off again, turning it a fraction clockwise, refitting and testing it till it read correctly.
Fiddly, but possible.
