Loosing Coolant
Loosing Coolant
hi all, 1st of all i have a 1.9 TD 406,
last few weeks ive noticed car is using about 1 litre of water, oil looks fine no signs of water mixing in there,
then other day when i was fitting my slpitter i noticed a dry white goo on the sump right next to the sump nut, the bottom of the engine is covered in this dry white goo stuff
does it sound expensive (might be my excuse to get rid and finally get 110 HDi)
thanks 8)
Re: Loosing Coolant
Gary406 wrote:hi all, 1st of all i have a 1.9 TD 406,
thanks 8)
1 litre per week , forgot to mention that
Re: Loosing Coolant
just had another look and its not a white goo its more of a dry white powder sort of thing, never seen this before
HimBigChief
Re: Loosing Coolant
Post by HimBigChief »
Check the bottom hose on the radiator near the drivers side wheel arch. My pipe and rad went and was leaking water from there. Ran back under the engine at speed and along the sump. Don't remember it leaving the white powder, but that could be because it's water oxidising an ally sump?
Image Image
Re: Loosing Coolant
yes thats what i mean mate oxidising, as all the sum nut is now WHITE
i will check those pipes later when i have a minute
thanks for the reply mate appreciate it 8)
jasper5
Re: Loosing Coolant
Post by jasper5 »
Check your water pump as well.
Re: Loosing Coolant
ok, thanks
also just noticed, were the oil filter goes on the front of the engine, there is a little ledge along the engineacross to the fuel filter housing,
this ledge has water sat on it
Busman
Re: Loosing Coolant
Post by Busman »
I would start with checking the rad and hoses. That is what went on mine.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
Re: Loosing Coolant
Also check around the thermostat housing for leaks, the seal goes very manky over time!
Pete64
Re: Loosing Coolant
Post by Pete64 »
mine was doing the same and i found the water pump had gone as the head gasket had gone, maybe something to check......
Re: Loosing Coolant
teamster1975 wrote:Also check around the thermostat housing for leaks, the seal goes very manky over time!
thanks teamster,
thermostat was changed in january 8) i'm gona check the 3 bolts that secure it 2moro,
thanks 8)
Re: Loosing Coolant
Busman wrote:I would start with checking the rad and hoses. That is what went on mine.
thanks mate will check all 2moro
thanks 8)
Re: Loosing Coolant
just a bit worried it could be the head gasket,
do the head gaskets on these often go ????????
Re: Loosing Coolant
It's not generally a problem area.
Re: Loosing Coolant
ok thanks, 8)
