Can my peugeot 406 2.1 hdi be remapped?
Jenny
Post by Jenny »
Can my peugeot 406 2.1 hdi executive P-reg be remapped and will it give me better fuel economy...
would it be worth me getting it done ??
At the risk of sounding silly...left hand side of my dash
a red light came on and i don't know what is...can anyone help
it looks like a cheese burger :oops:
Jenny.
swiss
Re: Can my peugeot 406 2.1 hdi be remapped?
Post by swiss »
there are companies which do diesel remaps. Most of those, if you Google for them, talk about the HDI engines. However I have seen at least one company in the UK offering to remap 2.1 engines. Bear in mind though that you engine is already tuned well towards the economy end, and when we talk about remaps it's usually to get more power at the expense of economy :)
The man with no car
I've just lost my reply to swiss's :roll:
Derv Doctor do/did a map for the 2.1. It is not an HDi engine but it is electronically controlled so can be re-tuned.
On diesels most owners can report better economy overall because the engine is not working so hard when cruising etc :|
Your 'cheeseburger' warning sounds like the low coolant level warning to me. You should check and top up the coolant (when engine cold) but also keep an eye on your radiator at the bottom for signs of leaks around the pipe connections. Also look at the left side of the engine (as you open the bonnet) for signs of leaks from the water pump which lives behind the cambelt cover but will show leaks at the bottom end. If its not losing coolant regularly the you should be ok.
StevieboyTD
Post by StevieboyTD »
The 2.1 is the non-ecu Lucas EPIC system, pretty much a basic mechanical unit.
Best option for tuning is to swap over to a Bosch injection system.
2.1td exec estate.
StevieboyTD wrote:...non-ecu Lucas EPIC system...
Err, it's drive-by-wire :?
StevieboyTD
I must have been asleep to miss the HDI part of the thread title!
Never knew they put HDI engines into p-reg 406s.
2.1td exec estate.
StevieboyTD wrote:I must have been asleep to miss the HDI part of the thread title!
They didn't, the HDi made its first appearance in the much-discussed D8.5 late S/T reg semi-facelift jobs in 1998.
The guy I bought my 2.1 off tried to tell me it was an HDi :roll: No, the 2.1 isn't, it's just a plain old TD. Hooray.
swiss
Post by swiss »
But it does have a fully electronic control.
The man with no car
I understood the 2.1 to be semi-electronically controlled and mappable as a result but it doesn't have the ubber-controls of the HDi.
Where's Jenny gone anyway? :lol:
swiss
Post by swiss »
She left when you took off your trousers :shock:
The man with no car
DiscoPol
Shiny New C5 2.2 Bi-turbo!
Post by DiscoPol »
swiss wrote:She left when you took off your trousers :shock:
they all seem to do that!
Maybe it was when my hairy testicle popped out? must get some new boxers :wink:
swiss
Post by swiss »
Someone pass me a paintball gun!
The man with no car
StevieboyTD
swiss wrote:But it does have a fully electronic control.
Really? I'll shut up then (first time for everything!), thought they were the basic fly-by-wire rheostat working the pump lever type units. Live and learn :)
2.1td exec estate.
