A couple of weeks ago, just after starting the engine stopped on tickover (e.g. when changing between forward and reverse) this then happened whenever the engine was ticking over. It didn't splutter or cough, just stopped much like turning off the ignition.
After a couple of hours it was then all fine and hunky dory again. And yesterday the problem started again. If it keep my foot on the accelerator a tad, then the engine keeps running, but does 'hunt' a little.
I've had a look under the bonnet and checked all the wiring connections etc, it all seems fine. Spark plugs are also good.
Any ideas as what is wrong? Where should I start looking?
kris
Engine stopping on tick over
Re: Engine stopping on tick over
Probably your stepper motor. It regulates the fuel/air mixture to the engine and can get clogged, causing this kind of issue.krissyn wrote:A couple of weeks ago, just after starting the engine stopped on tickover (e.g. when changing between forward and reverse) this then happened whenever the engine was ticking over. It didn't splutter or cough, just stopped much like turning off the ignition.
kris
Most of the time it manifests itself as an erratic/ unsettled tick over.
A few short rounds of revving solved it for me. Not that that is in anyway a suggested course of action.
I had play with the throttle, opening and closing it etc. I also disconnected the battery for a bit. After that tickover was fine, although a little high.
I also noticed a pronounced jolt when taking my foot off the accelerator, but I guess was the ECU readjusting itself.
Now it's settled down again it still keeps stopping.
Any further ideas?
If it worth getting the fault code read?
Any further ideas?
i had the same problem, but again i used a nice short red line session in second and third a couple of times and it has gone.
Althought i would go down the stepper route, may in fact be knackered rather than just dirty, or just very dirty!
Due to Recent Cutbacks, The Light at The End of The Tunnel Has Been Switched Off!
