When do you say enoughs enough :(
eoin27
The Irish 406 addict
Re: When do you say enoughs enough :(
Post by eoin27 »
mjb wrote:My £1000 V6 coupe has got through about £250 in parts and needs another £100 or so to get it just right.
No more trips to Ireland anytime soon in the coupe then eh? :lol:
mjb wrote:I still wish I'd kept the tubby estate though. I think I changed the brake pads and bought a set of tyres in 35,000 miles (1 year). It was solid, that thing *sniff*
Yes, it didn't even 'need' an oil change :lol: :lol:
Bugger that! :shock: Those roads turned a gunky PAS pipe into a full-blown leak, knocked the suspension geometry out (not sure how yet, but it doesn't handle right now), and turned my exhaust leak from something only noticeable by a smell with the bonnet open into a full blown fartfest :cry:
If I ever go back over there I'm taking a hire car! :shock:
Wanted, but not needed :oops: :lol:
swiss
Post by swiss »
Deprecation is enough of a reason in itself, for me. I mean I paid 400 for mine and TBH I expect it to sell for at least that, if not more. Granted I've put some money in to repairs and upgrades, but as I said I paid 400 quid for the thing and I've had it nearly three years. And its never failed to start on me ^_^
The man with no car
CountryPug
Post by CountryPug »
I'd say keep on with the good work mate, like someone else said 'better the devil you know' and at least you know the bits you've replaced won't need done again for a long time. I've had a similar session with my 406 lately, spent a few hundred in the last couple of months replacing bits and bobs. It's all part of owning an older car, keep the head up :)
Present - 95' 405 GLX TD
Previous - 01' 406 LX HDi
robb
Post by robb »
Mine failed MOT this week brakes Handbrake 2 rear tyres, headlight osr suspension bushes os headlight ended up with new bushes new headlight 2 new rearr discs and pads costing £535 including test fees on a £350 pound car its in good nick so worth spending on it .The costs easily creep up butat least its on the road for another year with no advisories
Bailes1992
Post by Bailes1992 »
It's going in next week to have the rear axle inspected and have a bloody good look at it. I might just focus on the back end for now and keep standard springs for the time being. Then a few months down the line I'll replace both front shocks and get lowering springs all around.
Is it normal for 406's to have slight rear camber?
lofty
2.2 16v
Post by lofty »
If its banging and rattling at the back, my money is on both suspension top links being buggered.
Not a massive job, Half hour a side, maybe £20 quid in parts tops.
Its rare for both rear dampers to give up the ghost at the same time.
IMO id get it done and use it for a bit longer. Most jobs on the 406 are at least "DIY able", unlike a lot of more modern stuff
2001 D9 406 Hdi 90bhp Rapier Estate - Platinum Silver
1999 306 GTi-6 Weekend Toy- Astor Grey
Bailes1992
Turns out the knocking was the outer bush of the near side trail arm which was replaced about 2 months ago... Took it back to the garage and its getting replaced FOC again :)
Nice result!
Brilliant! Bit worrying that it failed after two months though... :?
Bailes1992
Whats also abit worrying is the fact 1000miles after they replaced my engine mounts the top one come undon :roll:
Don't think you should be considering changing your *car*, mate.
Your *garage*, now, that's another matter :shock:
Bailes1992
highlander wrote:Don't think you should be considering changing your *car*, mate.
Yeh after the car threw me sideways around a roundabout for no reason and then once the garage phoned me up and told me the new bush failed I decided that was a good idea :(
sirwiggum
Post by sirwiggum »
Took the 406 to the exhaust place, new cat and flexi hose. There is now though a definite rumble off the exhaust at 1000 and 2000 rpms. Took it back but they can't find any more blows :shock:
Handbrake needs done.
Paintwork on the door edges where I sprayed with the official spray paint from the official paintcode doesn't match and is doing my head in.
Tempted to weigh it in against a Laguna Coupe....
