Throttle position sensor
jetdoc3
Post by jetdoc3 »
Can anyone tell me where I can get a Throttle position sensor for a 2000 90hp HDI? also I was wondering if anyone new whether or not I need to buy the whole assembly or if it was possible to replace just the potentiometer? cheers
Re: Throttle position sensor
The dealers will require your left testicle. I don't think anyone does a pattern part, I was having a search earlier but all I could find is the Pug part's 1/3 the price of the same thing from GM :shock:
Breakers I reckon, I did a search on Service Box a few days back viewtopic.php?f=3&t=11053&p=98279&hilit ... 920#p98279:
4 DOORS SALOON/EST AND INJECTION EW12J4 AND EEC 2000 DEPOLL (ENGINE)
COUPE 2 DOORS AND INJECTION EW12J4 AND EEC 2000 DEPOLL (ENGINE)
INJECTION ES9J4S
TURBO DIESEL DW10TD AND MOUNTING BOSCH UNTIL RPO NO. 09106 (15 Oct 2001)
TURBO DIESEL DW10TD AND SIEMENS ASSEMBLY
DW12TED4 TURBO DIESEL AND 4 DOORS SALOON/EST UNTIL RPO NO. 09701 (16 Oct 2001)
DW12TED4 TURBO DIESEL AND COUPE 2 DOORS UNTIL RPO NO. 09701
(That's just 406)
Also
1 document(s) found for 407
14 document(s) found for Partner (M59)
1 document(s) found for 306 new
7 document(s) found for 206 (T1)
6 document(s) found for 307
2 document(s) found for 307 new
2 document(s) found for 806
7 document(s) found for 807
4 document(s) found for 607
1 document(s) found for 607 new
3 document(s) found for EXPERT 3
2 document(s) found for Partner (M49)
10 document(s) found for Partner (M59)
1 document(s) found for EXPERT 1 & 2
7 document(s) found for XSARA PICASSO
5 document(s) found for C4
11 document(s) found for BERLINGO (M59)
1 document(s) found for XSARA
4 document(s) found for XSARA II
1 document(s) found for SYNERGIE
8 document(s) found for C8
2 document(s) found for C5 II
5 document(s) found for C5
1 document(s) found for C6
1 document(s) found for C5 (X7)
3 document(s) found for DISPATCH III
3 document(s) found for BERLINGO (M49)
13 document(s) found for BERLINGO (M59)
1 document(s) found for DISPATCH I & II
btw dealer price is 74 quid.
jetdoc3
Post by jetdoc3 »
Scanned my engine and found P0220 fault then Found the following on the net although the light is still there maybe I'll leave it
Don't suppose anyone knows anything about earthing fault mentioned below?[/color]
Thank you, screwloose; the code was P0220 with the message - throttle pedal position switch, B circuit. The light has not reappeared, I don't think I'll be taking any action unless advised otherwise.
Reply to this message | Report message as offensive | Link
Sat 5 Jul 2008 15:30
2000 2.0 engine management light, 406 hdi 90 - Screwloose
The scantool has picked the wrong code definition for your ECU there; for a Bosch EDC15 system P0220 is:-
"Accelerator pedal position sensor B - circuit malfunction."
This is one of the codes the official wiring modification was intended to stop. If/when it returns; get your garage to carry out the earthing change - but make sure they understand what they are doing, if there's going to be any chance of it working.
[/color][/i]
