rear passanger door leaking
i had a big puddle in my rear footwell a few months ago and couldnt work out where it came from, but ive now noticed drips coming from under the door sill into the car, what do i do to stop this? its coming from under about where the window winder is.
- highlander
- PowerFlow Shill
Re: rear passanger door leaking
Hi
I'd check the rubber door seals; make sure there's no damage or signs of perished rubber.
If in doubt, get them replaced - they shouldn't be too costly
Kind regards
Graeme
Kind regards
Graeme
If you remove the door card there should be a kinda membrane or plastic sheet liner thing and frequently past owners can damage this liner (whilst changing a locking solenoid or speaker etc) without realising what it's for (catching and draining any stray water from the window correctly) - this would be my first port of call but you are likely to need a set of 'torx' screw driver heads for some of the fixings on the door card.
if its the door seals and if its a d8 ive got some good ones here nice and cheap
- DaiRees
My D8 used to have a leaky door, it turned out to be a shredded water shedder as Welly said. It appears that I wasn't the first owner to experience a dodgy lock on that door
Further investigation identified that Mr scissorhands had had a go at all my doors!
its a 97 sri, dunno if thats D8 or not lol, well when i press on the seal water trickles out so not sure whats wrong with the seal, looks pretty much as it should i think.
i just removed the rear door card and all i have behind is a polystyrene foam cover, no plastic sheeting, i couldnt see any signs of dampness tho. the seals have a few tears in but then the seals have holes in them anyway so it cant be the tears? dunno what it is
