Wipers blowing fuse
Re: Wipers blowing fuse
Hmm ok, sounds like it is probably worth trying to fix mine then. Thanks guys!
Finally got a chance to look at this tonight. Sure enough that voltage suppressor had split clean in two! Soldered a new one in and seems to be alright so far
Thanks for the help!!
Good
Glad you got it solved!
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater - just hit 710.000 kms
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Previously owned:
Splendid news, well done
Voltage suppressor? Was it that diode? Any pics?
Yes it was the one from that French forum posted near the beginning. The spec sheet called it a voltage suppressor. Sorry didn't take any pictures, I was in a rush!
Not to worry, I'll have to see what I can glean from the French site.
I'm annoyed the BM34 diagram doesn't show it, I guess it suppresses the voltage going the wrong way, maybe when it passes the park position
